Yes,
That helps a bunch. I'm making a breakout board for my SnapAmp. While
specific to my needs, I imagine it might make a good starting point for
someone else, so I intend on publishing the eagle CAD files somewhere
when I'm done.
- Steve
Hi Steven,
There is no problem feeding in 5V differential signals directly int the
SnapAmp differential inputs. That is what they were designed for.
A 120 Ohm termination resistor across each + and - input (2 per encoder)
would be a good idea if your encoders are capable of driving that load.Â
SnapAmp doesn't have any termination on board.
+5V passes straight through the boards and through the connectors so the
main limitation is the ~1A limit of the connectors. You should be able
to draw at least 500ma for your encoders which would typically be more
than enough for most encoders.
HTHRegardsTK
steve@... [DynoMotion]" <
DynoMotion@yahoogroups.com>
To:
Sent: Saturday, February 14, 2015 3:42 PM
Subject: [DynoMotion] SnapAmp quadrature encoder inputs
 What voltages can the SnapAmp quadrature inputs handle? My servo
encoders
are powered from 5V and have differential outputs. Should this be a
problem? Also, do the differential inputs need to be terminated with a
120 Ohm resistor across them, like the SmoothStepper does? Finally, how
much +5V can I take from the SnapAmp on connector JP7? I'm not sure how
much my encoders require, so either way I'm most likely to provide my own
5V supply to the encoders.
Steven Ciciora
#yiv5840612031 #yiv5840612031 -- #yiv5840612031ygrp-mkp {border:1px
solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0
10px;}#yiv5840612031 #yiv5840612031ygrp-mkp hr {border:1px solid
#d8d8d8;}#yiv5840612031 #yiv5840612031ygrp-mkp #yiv5840612031hd
{color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
0;}#yiv5840612031 #yiv5840612031ygrp-mkp #yiv5840612031ads
{margin-bottom:10px;}#yiv5840612031 #yiv5840612031ygrp-mkp
.yiv5840612031ad {padding:0 0;}#yiv5840612031 #yiv5840612031ygrp-mkp
.yiv5840612031ad p {margin:0;}#yiv5840612031 #yiv5840612031ygrp-mkp
.yiv5840612031ad a {color:#0000ff;text-decoration:none;}#yiv5840612031
#yiv5840612031ygrp-sponsor #yiv5840612031ygrp-lc
{font-family:Arial;}#yiv5840612031 #yiv5840612031ygrp-sponsor
#yiv5840612031ygrp-lc #yiv5840612031hd {margin:10px
0px;font-weight:700;font-size:78%;line-height:122%;}#yiv5840612031
#yiv5840612031ygrp-sponsor #yiv5840612031ygrp-lc .yiv5840612031ad
{margin-bottom:10px;padding:0 0;}#yiv5840612031 #yiv5840612031actions
{font-family:Verdana;font-size:11px;padding:10px 0;}#yiv5840612031
#yiv5840612031activity
{background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv5840612031
#yiv5840612031activity span {font-weight:700;}#yiv5840612031
#yiv5840612031activity span:first-child
{text-transform:uppercase;}#yiv5840612031 #yiv5840612031activity span a
{color:#5085b6;text-decoration:none;}#yiv5840612031
#yiv5840612031activity span span {color:#ff7900;}#yiv5840612031
#yiv5840612031activity span .yiv5840612031underline
{text-decoration:underline;}#yiv5840612031 .yiv5840612031attach
{clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
0;width:400px;}#yiv5840612031 .yiv5840612031attach div a
{text-decoration:none;}#yiv5840612031 .yiv5840612031attach img
{border:none;padding-right:5px;}#yiv5840612031 .yiv5840612031attach
label {display:block;margin-bottom:5px;}#yiv5840612031
.yiv5840612031attach label a {text-decoration:none;}#yiv5840612031
blockquote {margin:0 0 0 4px;}#yiv5840612031 .yiv5840612031bold
{font-family:Arial;font-size:13px;font-weight:700;}#yiv5840612031
.yiv5840612031bold a {text-decoration:none;}#yiv5840612031
dd.yiv5840612031last p a
{font-family:Verdana;font-weight:700;}#yiv5840612031
dd.yiv5840612031last p span
{margin-right:10px;font-family:Verdana;font-weight:700;}#yiv5840612031
dd.yiv5840612031last p span.yiv5840612031yshortcuts
{margin-right:0;}#yiv5840612031 div.yiv5840612031attach-table div div a
{text-decoration:none;}#yiv5840612031 div.yiv5840612031attach-table
{width:400px;}#yiv5840612031 div.yiv5840612031file-title a,
#yiv5840612031 div.yiv5840612031file-title a:active, #yiv5840612031
div.yiv5840612031file-title a:hover, #yiv5840612031
div.yiv5840612031file-title a:visited
{text-decoration:none;}#yiv5840612031 div.yiv5840612031photo-title a,
#yiv5840612031 div.yiv5840612031photo-title a:active, #yiv5840612031
div.yiv5840612031photo-title a:hover, #yiv5840612031
div.yiv5840612031photo-title a:visited
{text-decoration:none;}#yiv5840612031 div#yiv5840612031ygrp-mlmsg
#yiv5840612031ygrp-msg p a span.yiv5840612031yshortcuts
{font-family:Verdana;font-size:10px;font-weight:normal;}#yiv5840612031
.yiv5840612031green {color:#628c2a;}#yiv5840612031
.yiv5840612031MsoNormal {margin:0 0 0 0;}#yiv5840612031 o
{font-size:0;}#yiv5840612031 #yiv5840612031photos div
{float:left;width:72px;}#yiv5840612031 #yiv5840612031photos div div
{border:1px solid
#666666;height:62px;overflow:hidden;width:62px;}#yiv5840612031
#yiv5840612031photos div label
{color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv5840612031
#yiv5840612031reco-category {font-size:77%;}#yiv5840612031
#yiv5840612031reco-desc {font-size:77%;}#yiv5840612031
.yiv5840612031replbq {margin:4px;}#yiv5840612031
#yiv5840612031ygrp-actbar div a:first-child
{margin-right:2px;padding-right:5px;}#yiv5840612031
#yiv5840612031ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica,
clean, sans-serif;}#yiv5840612031 #yiv5840612031ygrp-mlmsg table
{font-size:inherit;font:100%;}#yiv5840612031 #yiv5840612031ygrp-mlmsg
select, #yiv5840612031 input, #yiv5840612031 textarea {font:99% Arial,
Helvetica, clean, sans-serif;}#yiv5840612031 #yiv5840612031ygrp-mlmsg
pre, #yiv5840612031 code {font:115% monospace;}#yiv5840612031
#yiv5840612031ygrp-mlmsg * {line-height:1.22em;}#yiv5840612031
#yiv5840612031ygrp-mlmsg #yiv5840612031logo
{padding-bottom:10px;}#yiv5840612031 #yiv5840612031ygrp-msg p a
{font-family:Verdana;}#yiv5840612031 #yiv5840612031ygrp-msg
p#yiv5840612031attach-count span
{color:#1E66AE;font-weight:700;}#yiv5840612031 #yiv5840612031ygrp-reco
#yiv5840612031reco-head {color:#ff7900;font-weight:700;}#yiv5840612031
#yiv5840612031ygrp-reco {margin-bottom:20px;padding:0px;}#yiv5840612031
#yiv5840612031ygrp-sponsor #yiv5840612031ov li a
{font-size:130%;text-decoration:none;}#yiv5840612031
{font-size:77%;list-style-type:square;padding:6px 0;}#yiv5840612031
#yiv5840612031ygrp-sponsor #yiv5840612031ov ul {margin:0;padding:0 0 0
8px;}#yiv5840612031 #yiv5840612031ygrp-text
{font-family:Georgia;}#yiv5840612031 #yiv5840612031ygrp-text p {margin:0
0 1em 0;}#yiv5840612031 #yiv5840612031ygrp-text tt
{font-size:120%;}#yiv5840612031 #yiv5840612031ygrp-vital ul
li:last-child {border-right:none !important;}#yiv5840612031
